1 AP not broadcasting SSID
  • 1.  1 AP not broadcasting SSID
    Posted May 15, 2018 06:30 AM
    i have around 400s APs in one site, one outdoor AP-275 is not broadcasting any SSID. other APs on the same ap-group are broadcasting fine and there is no specific AP configuration. any input what might gone wrong? here is what i have checked:
    other outdoor ap with the same ap-group broadcasting fine (PA-GRASSLAWNEW-test the one at the bottom is the one having issue)
    (Aruba7210) #show ap active | include 275
    PA-Lagoon2         PADMALEGIAN_OUTDOOR  16.0.2.105  5            AP:HT:11/15/20       0            AP:VHT:157/18/20     275      Ea     1d:23h:55m:23s    N/A
    PA-POOL 2            PADMALEGIAN_OUTDOOR  16.0.3.154  6            AP:HT:11/15/20       1            AP:VHT:153/18/20     275      Ea     1d:23h:54m:7s    N/A
    PA-NS                PADMALEGIAN_OUTDOOR  16.0.0.248  5            AP:HT:1/18/20        1            AP:VHT:153/18/20     275      Ea     1d:23h:55m:23s   N/A
    PA-POOL INFINITY    PADMALEGIAN_OUTDOOR  16.0.2.115  28           AP:HT:11/18/20       8            AP:VHT:161/18/20     275      Ea     1d:23h:55m:24s    N/A
    PA-POOL1               PADMALEGIAN_OUTDOOR  16.0.3.153  4            AP:HT:11/18/20       0            AP:VHT:153/18/20     275      Ea     1d:23h:54m:9s    N/A
    PA-LAGOONFAMILY        PADMALEGIAN_OUTDOOR  16.0.2.40   11           AP:HT:11/18/20       0            AP:VHT:161/18/20     275      Ea     1d:23h:55m:21s   N/A
    PA-Lagoon3           PADMALEGIAN_OUTDOOR  16.0.2.47   2            AP:HT:11/15/20       0            AP:VHT:161/15/20     275      Ea     1d:23h:55m:24s   N/A
    PA-Lagoon1           PADMALEGIAN_OUTDOOR  16.0.0.164  5            AP:HT:6/18/20        1            AP:VHT:161/15/20     275      Ea     1d:23h:55m:26s   N/A
    PA-GRASSLAWNEW-test  PADMALEGIAN_OUTDOOR  16.0.2.99   0                                 0                                 275      E      6m:41s           N/A
    show ap showing the AP's radios are off
    (Aruba7210) #show ap active | include PA-GRASSLAWNEW-test
    bss table is empty
    (Aruba7210) #show ap bss-table ap-name PA-GRASSLAWNEW
    fm (forward mode): T-Tunnel, S-Split, D-Decrypt Tunnel, B-Bridge (s-standard, p-persistent, b-backup, a-always), n-anyspot
    Aruba AP BSS Table
    bss  ess  port  ip  phy  type  ch/EIRP/max-EIRP  cur-cl  ap name  in-t(s)  tot-t  mtu  acl-state  acl  fm
    Channel followed by "*" indicates channel selected due to unsupported configured channel.
    "Spectrum" followed by "^" indicates Local Spectrum Override in effect.
    Num APs:0
    Num Associations:0
    debug received-config shows blank
    (Aruba7210) #show ap debug received-config ap-name PA-GRASSLAWNEW-test
    radio profile is enabled and set to ap-mode
    (Aruba7210) #show rf dot11g-radio-profile OUTDOOR
    802.11g radio profile "OUTDOOR"
    Parameter                                      Value
    Radio enable                                   Enabled
    Mode                                           ap-mode
    should i conclude if this is a hardware problem?
  • 2.  RE: 1 AP not broadcasting SSID
    Posted May 15, 2018 06:40 AM
    You should open a TAC case so that they can obtain the tech support.  That would be a good start.
  • 3.  RE: 1 AP not broadcasting SSID
    Posted May 15, 2018 06:45 AM
    yeah i already opened a TAC case but hoping to get a quicker solution from here.
  • 4.  RE: 1 AP not broadcasting SSID
    Posted May 15, 2018 06:54 AM
    Type "show ap debug driver-log ap-name <name of ap>"
    That might give you a clue.
  • 5.  RE: 1 AP not broadcasting SSID
    MVP EXPERT
    Just check the AP275 is permitted in your regulatory domain, you can use the command below. This example is using GB and AP275
    (Aruba620) #show ap  allowed-channels country-code GB ap-type 275
  • 6.  RE: 1 AP not broadcasting SSID
    Posted May 15, 2018 07:03 AM
    Hi Colin,
    my customer already went home, will try that tomorrow.
    Hi Zalion,
    that's why i checked other similar APs first.
  • 7.  RE: 1 AP not broadcasting SSID
    Posted May 15, 2018 11:40 PM
    Hi Ricky,
    Please check the output for :
    (Aruba) #show ap debug system-status ap-name <name of AP>  | begin Power
    This is justo make sure AP is not running on low power due to which the radios might be disabled.
