100% CPU Load - External Captive Portal with Radius and XML API
  • 1.  100% CPU Load - External Captive Portal with Radius and XML API
    Posted May 15, 2015 04:09 AM
    We have problem our CPU load increase to 100% when we deploy our External Captive Portal with Radius and XML API.
    We use XML API to authenticate and change the role of use and the Radius use for AAA.
    How do we know in CLI what processes makes the CPU load comes to 100% ? Or is there any way to reduce the CPU load?
    Specs: Aruba 3400 Access Controller
    Current Authenticated User : 88/550
    Bandwidth Speed allotted to AC: 40-50mbps
    Thank you,
    BienJerico
  • 2.  RE: 100% CPU Load - External Captive Portal with Radius and XML API
    Posted May 15, 2015 05:47 AM
    Benjerico,
    What version of ArubaOS is this?
  • 3.  RE: 100% CPU Load - External Captive Portal with Radius and XML API
    Posted May 15, 2015 06:50 AM
    Aruba OS 6.2.1.7
  • 4.  RE: 100% CPU Load - External Captive Portal with Radius and XML API
    Posted May 20, 2015 02:55 AM
    BienJerico
    did the issue happen only as a result of xml api, or did you bring up all the services at the same time ?
    by the way, 6.2 is wayyyyyy unsupported - but the problem I suspect you are hitting is generic to all releases. Please collect
    show cpuload
    show cpuload current
    do you see httpd chewing all the CPU (if not httpd, then what other process) ?
    if it is httpd then this will be due to https, there are some workarounds for it - will advise after your confirmation.
    regards
    -jeff
