last person joined: 5 hours ago
2nd DNS does not stay
  • 1.  2nd DNS does not stay
    Posted Mar 30, 2012 01:44 PM
    I noticed that the 2nd DNS server on the internal DHCP server does not stay. I have added it several times and saved the configuration. I click on something else then go back to the internal DHCP server and the 2nd DNS server is gone. I made sure there was a space in between the servers when configuring. Running Aruba OS 5.0.3.3.
  • 2.  RE: 2nd DNS does not stay
    Posted Mar 30, 2012 01:46 PM
    Type "show audit-trail" to see what was configured.
  • 3.  RE: 2nd DNS does not stay
    Posted Mar 30, 2012 01:51 PM
    When I run "show audit-trail" it just shows login info.
  • 4.  RE: 2nd DNS does not stay
    Posted Mar 30, 2012 01:59 PM
    When I do a "show run" and go to where the IP pool is it only see one of the DNS servers.
  • 5.  RE: 2nd DNS does not stay
    Posted Mar 30, 2012 02:03 PM
    did you confirm the pressing both apply buttons I mention in the above post?   if so, did you try the CLI command rather than WebUI?
  • 6.  RE: 2nd DNS does not stay
    Posted Mar 30, 2012 02:04 PM
    As mentioned earlier by clembo, please hit apply on both pages
    Network > IP > DHCP > Edit DHCP Pool (guest) -> Add Multiple DNS entries -> Apply
    As soon as you hit Apply, it will take you back to following page where you have to hit Apply again.
    Network > IP > DHCP Server -> Apply
    Make sure you see a message saying "Configuration Updated Successfully"
  • 7.  RE: 2nd DNS does not stay
    Posted Mar 30, 2012 03:09 PM
    It would only save when going to CLI worked. Thanks.
  • 8.  RE: 2nd DNS does not stay
    Make sure that you hit Apply on both the page where you defined the second DNS server, but then also again on the next page that shows the the pools and exclusions/etc.  That second apply  is often missed.
    If you continue to have problems; put it in through the CLI:
    ip dhcp pool "PoolNamel" dns-server 8.8.8.8 4.2.2.2
