3/4G USB Stick for Controller
  • 1.  3/4G USB Stick for Controller
    Posted Nov 24, 2016 07:53 AM
    are the 3G/4G Sticks supported for the controllers as internet uplinks ? IF yes, does anyone have a config for that ? If i search i only find Instant or RAP Config Guides.
    Thanks in advance!
  • 2.  RE: 3/4G USB Stick for Controller
    Posted Dec 05, 2016 05:52 AM
    They are supported in the 600 series of controllers. I'm not aware that they are supported in others though.
    ArubaOS user guide (6.4) page 988 tells yo9u about it and the following link shows you the supported USB Peripherals.
    Cheers
    James
