303H Config Wired-Port on Campus AP
  • 1.  303H Config Wired-Port on Campus AP
    Posted Sep 20, 2017 11:37 PM
    I have a 303H 1 unit , so I config to IAP and Wired-port and it's work , but I need to know if convert 303H from IAP to Campus AP then how to config Wired-port or It's can't config Wired-port on Campus AP Mode
    Thank You.
  • 2.  RE: 303H Config Wired-Port on Campus AP
    Posted Sep 21, 2017 03:32 AM
    If you convert the 303H to a Campus AP, what the wired ports do are controlled with the AP> Wired AP profile in the ap-group of the configuration for that AP.
  • 3.  RE: 303H Config Wired-Port on Campus AP
    Posted Sep 21, 2017 03:39 AM
    Thank you for reply , I'll try soon
