315 AP's not showing as UP on the controller
Hi All
I have installed 69 315 IAP at  new office, all  been managed by 2x 7205
controller (still running AOS 6)
The issue is 7 out of the 69 will not show as "UP" on the controller
Steps takan
- converted them from IAP to CAP
- made sure they are in the correct VLAN
- they have received an IP in the correct range
- I can ping them from the controller and switches
They did briefly appear in the default group as "UP" but as I went to provision them into the new AP group the controller said "AP is down"
The AP's then just disappear and then  reappeared as "down"
- I have powered off the POE port and back on again but still nothing
- Dont have Telnet or SSH access to the them
  Other than having to take of the mount on the celiings and resetting
  them  via consol is there anything else I can try ?
Thank you
Frequent Contributor II
Re: 315 AP's not showing as UP on the controller
Which ArubaOS 6.x version are you running?
Do you have control-plane security enabled with auto-cert provisioning enabled?
What does "show ap database" (from the CLI) say?
ACMX#255 | ACDX#742 | ACCX#746 | AMFX#25 | ACMP | ACCP | AWMP
www.securelink.nl
Hi
Version:6.5.1.4
CPsec is disabled
I have cleared those AP's again from the controller and here is the sequence:
- They reappear as UP in the default group
- As soon as I go to provision the AP it goes down
- it then stays down
Please see attached screenshots
I have also check POE power allocation on the switch
Spanning tree blocked ports
I am still able to ping the AP's from the controller after the go into the "down" state
thank you very much
Type "show log system 50" to see if you can get a reason why those APs are going down.
Do you have a firewall between the APs and the controller?  MPLS link?
Hi Colin
Please see attached the logs
I have a fairly simple Layer 2 network with Gateways
on the core and routing from there on.
There is only a firwall for WAN breakout but the
controllers are directly connected to the Core
The AP that shows up in the logs attached
is on the same switch with 4 other AP's
that are working
All ports are configured exactly the same
I am starting to think (having looked at the logs) it could be a access port issue on the access switch., the patch panel or a cabling issue?
Or lastley the actual AP's themselves?
thanks again
Try to test or replace the cabling if you can.
See if the port negotiated the proper duplex. If you are providing POE see if the switch is oversubscribed.
Hi Colin,
So in total there was 6 AP's listed on the controller as DOWN
3 in floor 9
2 in floor 11
1 in floor 12
removed the AP's from the ceiling on floor 9 plugged them directly into the switch waited for about 10 Min
 did not see the logs like before:
(HELLO-TIMEOUT, 238 sec before: Last Ctrl msg: HELLO len=1362 dest=172.16.55.11 tries=10 seq=0)
The AP's then came UP, the AP's on the other floors then also also came UP , plugged the AP's from the 9th floor back into the patch ports in the ceiling and they came UP again
So cant explain what the issue was and how the AP's on the other floors also came UP at the same time without touching them but hey everything is working now
thanks for you help
I didn't do anything.  You troubleshot it yourself.  Do you have any special configuration on your switchports?
Hi Colin
Nothing special
untagged the AP Vlan on the access ports
tagged the AP Vlan on the 2 x 10Gig trunk - LACP, up to the core
thank you
