Hey all. So I have a controller that I recently reset back to factory settings. When it came up after the reset it promted via the wizard for an IP address for VLAN 1.
At that time I did not enter the IP address and shut it off. Now when I plug it in I get nothing off the serial port (Known working cable) and the status light stays red.
This unit was working fine previously, could the config be corrupt now causing it not to boot? What can I do? Hardware reset??
#3400
