Sometimes when client roaming 5ghz its connecting to 2.4 Ghz .
What could be the reason . Since the client decide where to connect ,can we change the behaviour .
What is inter-band roaming
There could be lots of reasons. One reason could be: if DFS channels are being used, the client might not support them. Worth checking...
Cheers
James
I am not using any dfs channels . This could be the client listens 2.4 signal better than 5 Ghz?
This happens when client roam .
