6.1.3.9 - RAP console shows incorrect info
  • 1.  6.1.3.9 - RAP console shows incorrect info
    Posted Jan 25, 2014 12:17 PM
    I've just noticed on my RAP running 6.1.3.9 that when I go to the RAP console, it is showing incorrect information.
    The 2.4GHz ssids only use 20 MHz channels as usual, but the dashboard shows 2.4GHz-HT-40MHz.
    Not really a big deal, but could be misleading if I was troubleshooting a customers RAP.
    That might have been fixed in later versions, but not sure.
  • 2.  RE: 6.1.3.9 - RAP console shows incorrect info
    Posted Jan 25, 2014 12:54 PM
    Please open a support case with TAC so we can replicate this using your config and specific setup.
  • 3.  RE: 6.1.3.9 - RAP console shows incorrect info
    Posted Jun 03, 2014 12:29 PM
    Just though I'd update on this, based on what TAC said.
    They were very confused that I was able to get the rapconsole on a campus ap that had been converted.  I got the same thing on another AP and also another version.
    Anhow, the information shown is incorrect and just shows that the radio is capable of 40-MHz channels, but doesn't mean it actually is using them.
    Nevertheless, still misleading.
  • 4.  RE: 6.1.3.9 - RAP console shows incorrect info
    Posted Jun 03, 2014 04:58 PM
    RAP console on a campus AP? really?
  • 5.  RE: 6.1.3.9 - RAP console shows incorrect info
    Posted Jun 04, 2014 02:30 AM
    yep.  strange but true.  I tried on an AP105 and same thing.
