620 controller not booting - PANIC DUMP INITIATED!!!
Well I've gone and done it now and seem to have bricked my lab 620 controller.
Initially I tried to upgrade to 6.4.2.5 but it kept saying no space, despite clearing everything out.
I then upgraded the partition via cpboot which seemed to work fine.
After a reboot, this is where the problems started.  Initially it did reboot, but came back with an error about upgrading the boot image, and the image on the old partition was gone.
I upgrade that partition via cpboot to it's previous version and now the thing has gone completely haywire.
           <<<<<    Welcome to Aruba Networks - Aruba A620-4    >>>>>
Checking Inventory...OK
Starting watchdog processes
Check/update Boot Image
 Inside wd_intr_handler
rmi_bridge_lock is already taken from panic cpu
cpumask = f ipi_mask = f and dump_mask = 0
Value after sending ipi jiffies = 0x00001964 jiffies_64 = 0x0000000000001964
Waiting for dumps to complete  jiffies = 0x00001964 jiffies_64 = 0x0000000000001964
<0>
SYSTEM WILL REBOOT MOMENTARILY
JIFFIES = 0x00001964 JIFFIES_64 = 0x0000000000001964
 Same thing booting into either partition.
Is it possible to recover from this?
Unfortunately no support since this is a lab controller.
ACCP, ACCX #817, ACMP, ACMX #294
Re: 620 controller not booting - PANIC DUMP INITIATED!!!
Have you tried this:
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Tutorial-How-to-fix-a-corrupt-OS/td-p/150468
Thank you
Victor Fabian
Lead Mobility Architect
Unfortunately this is happening on both partitions
Moderator
hi Michael
Can you post (attachment) the full log of the bootup from power on.
regards
-jeff
Jeff, boot log below.
I was looking at this article link but I don't seem to have the format command available.
CPBoot 1.0.0.0 (build 23274)
Built: 2010-01-19 at 11:11:22
DDR2 DRAM running at 466Mhz
DRAM:  Total = 512 MB
POST:  Memory test: Physical 0 - 0x10000000 - quick test
       Memory test: Physical 0x10000000 - 0x20000000 - quick test
       PASS
CPU:   XLS204, rev. A1 Clock: 600MHz
CPLD:  rev: 1.3
SMP:   All 4 cpus successfully started
Board: A620
POST2: OK
PCIE:  RC2x2 mode
Net:  xls_gmac0, xls_gmac1 [PRIME]
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xca ( NAND 256MiB 3,3V 16-bit)
Boot:  Primary bootflash partition
Hit any key to stop autoboot:  0
booting system partition 1
part offset: 3200000 part size: 3200000
### JFFS2 loading 'uImage' to 0x87000000
Scanning JFFS2 FS:   load: loaded 'uImage' to 0x87000000 (62697896 bytes)
### JFFS2 load complete: 62697896 bytes loaded to 0x87000000
Booting image...
Image is signed; verifying checksum...
passed
Signer Cert OK
Policy Cert OK
RSA signature verified.
No network device to cleanup
Jumping to the application... 0x80678000
Linux command line:  run quiet console=ttyS0,9600
Downloading SOS...done.
Uncompressing core image files...done.
Mounting the flash file systems...done.
Tuning IPv4 route cache...done.
Aruba Networks
ArubaOS Version 6.3.1.9 (build 44832 / label #44832)
Built by p4build@majorca.arubanetworks.com on 2014-07-15 at 12:57:37 PDT (gcc version 3.4.3)
Copyright (c) 2002-2014, Aruba Networks, Inc.
Value after sending ipi jiffies = 0x00001c39 jiffies_64 = 0x0000000000001c39
Waiting for dumps to complete  jiffies = 0x00001c39 jiffies_64 = 0x0000000000001c39
<0>
PANIC DUMP INITIATED!!!  - SYSTEM WILL REBOOT MOMENTARILY JIFFIES = 0x00001c39 JIFFIES_64 = 0x0000000000001c39
Moderator
Michael
Give the following a go
cpboot> purgeenv
cpboot> run wipe-out-flash
cpboot> reset
then interrupt the bootup, and re-do the setenvs for your TFTP server, use any one of the fastEthernet ports (labelled 0-7). I have found before you may need to saveenv after all the ip/netmask/gateway/serverip is setup, so saveenv, reset and check you can ping the server IP. If it works, then upgrade as shown:
cpboot> upgrade 0 ArubaOS_6xx_5.0.3.0_26207
partition start= 0 partition size= 52428800
Starting TFTP Download ...
Using xls_gmac1 device
TFTP from server 172.20.0.1; our IP address is 172.20.0.2
Filename 'ArubaOS_6xx_5.0.3.0_26207'.
Load address: 0x87000000
Loading: #################################################################
done
Bytes transferred = 42168224 (2836fa0 hex)
see if that unsticks it.
regards
-jeff
Jeff.  You're a star....that has done the trick, with a little bit of wrangling.
I was able to boot up, but it gave the following error.
(aruba-lab) #show image version
Ancillary files are not present
* WARNING:  An additional image upgrade is required to complete the *
* installation of the AP and WebUI files. Please upgrade the boot   *
* partition again and reload the controller.                        *
Ancillary file(s) or digest file missing.
Ancillary image is missing please upgrade the image again.
Partition               : 0:0 (/dev/mtdblock9) **Default boot**
Software Version        : ArubaOS 6.3.1.9 (Digitally Signed - Production Build)
Build number            : 44832
Label                   : 44832
Built on                : Tue Jul 15 12:57:37 PDT 2014
Partition               : 0:1 (/dev/mtdblock10)
 Tried to upgrade partition 1 but this failed giving the following.
Upgrading partition 1
Secure file copy:....................................................
File copied successfully.
Saving file to flash:
Error upgrading image: Couldn't erase image partition
 So I upgraded partition 1 via cpboot method which seemed to work, but this time I made sure I didn't boot into that one.  I booted into partition 0 and still got the message about Ancillary Files missing etc.
Upgraded partition 1 via normal method in cli and this seemed to work.
Changed the boot statement to load partition 1, reloaded and crossed fingers.
All good now.  :-)
This all started when I couldn't upgrade due to insufficient space, despite clearing all files out.  I suspect that if I had done a 'write erase all' and the restored the flashbackup I wouldn't have had the problem.
Anyhow...lesson learnt.  Good thing it wasn't a customers equipment.
Moderator
Michael
glad to know it's recovered eventually! yes, the 6xx gets a bit dicey once it's running dual 6.4 images, cleaning up as much as you can and then rebooting prior to any attempt to upgrade can usually help.
regards
-jeff
