650 Rack Mount Options
  • 1.  650 Rack Mount Options
    Posted Feb 17, 2012 08:11 PM
    Can someone tell me if the 650 comes with mounting ears of if you need to order the below:
    HW-620-MNT-19Aruba 620 19" Equipment Rack Mounting Kit
    Thanks!
  • 2.  RE: 650 Rack Mount Options
    Posted Feb 17, 2012 08:16 PM
    HW-620-MNT-19 Aruba 620 19" Equipment Rack Mounting Kit
    Thanks!
    Rackmount equipment comes in the 650 box, according to the 650 Installation Guide on the support site:
    Package Checklist:
    Aruba 650 Series Mobility Controller
    AC Power Cord (country-specific)
    Rack Mount Brackets with Hardware (for rack mounting) Left Side Bezel (not installed)
    Right Side Bezel (not installed)
    The kit you are referring to, is for the 620 series, not the 650.
  • 3.  RE: 650 Rack Mount Options
    Posted Feb 17, 2012 10:15 PM
    I had looked at the datasheet docs for hardware included, but not the installation guides. Thanks CJ!
  • 4.  RE: 650 Rack Mount Options
    Posted Feb 20, 2012 11:58 AM
    I found that to be confusing myself.  I think docs need to be clearer that a 650 comes with 19" rackmount ears.  I actaully bought a 620 rackmount kit just in case, but didn't end up needed it, obviously.
  • 5.  RE: 650 Rack Mount Options
    Posted Apr 03, 2012 11:33 AM
    Hello, i have an offer for you. If you need an 650 rackmount kit we can make a deal. I can send you the rackmount for free if you send me those orange sidewals which should be removed when installing rackmount.
  • 6.  RE: 650 Rack Mount Options
    Posted Aug 28, 2012 11:58 PM
    I'll take that offer if its still open!
