last person joined: 9 hours ago
650 firmware upgrade options
  • 1.  650 firmware upgrade options
    Posted Apr 25, 2014 11:23 PM
    I just upgraded the firmware on my Dell W650 controller to version 6.4.0.3.  I applied the upgrade to the non-boot partition, and after reboot everything appears to be functioning fine.  However, now through the WebUI when I go to Maintenance > Image Management, for the "Upgrade Using" option, the radio button for "Local File" is grayed out and I can't select it.  I can still select TFTP, FTP, SCP, or USB.  Has this option been removed?
  • 2.  RE: 650 firmware upgrade options
    Posted Apr 25, 2014 11:31 PM
    Ugh.  Nevermind.
    Just found the section in the release notes that mentions that this is disabled since version 6.3.1.  Annoying, but I can work around it.
