I know this is fully supported on the RAP-5 now, but has it been added to the 600 series controllers yet?
I decided to try anyways. I am running 6.1.3.3. Controller sees it, but errors with the following:
Created a new cellular profile; using the import of the 290 information.
Attempted to use both the 3G dialer (evdo_us) and some custom 4G ones I made off trying to piece together the Init and Dial strings....but had no luck. Each time I get:
Error: Timed out sending AT commands. #4
Are there any "immediate" plans to support the UML290 from the 600 series controllers?
