Hello Community.
I'm needing a document that indicates that the controller 7200 Series support QoS for IPv6.
I found in the ArubaOS 6.4.3.x manual (https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=19384) page 138 that WMM QoS IPv6 is not supported in APs.
The ArubaOS manual do not indicate QoS for IPv6.
Please, the question:
1. Do you know if the controller 7200 Series offer QoS for IPv6?
2. Is there a public doc that I can share with the customer?
Thanks in advance,
HIT
