MVP
Re: 7220 HA DATA NOT SYNCRONIZING
In that case you can configure it as Master-Local where both controllers can serve AP’s. You will need to create ap-groups pointing to controllers.
However, as you said, your scenario will not be fully redundant and you cannot choose which AP’s will be down.
I’d add an additional controller to have a fully redundant network.
Borja
ACMX #567 //ACCP//CWNA//CWAP
Hi borja can you please send me the configuration of the master-local controller
MVP
Please check the VRD, it explains very well how to create a master-local scenario.
https://www.arubanetworks.com/vrd/CampusWNetworksVRD/wwhelp/wwhimpl/js/html/wwhelp.htm#href=Chap5_Redundancy.html
Borja
Is this your post as well? http://community.arubanetworks.com/t5/Wireless-Access/AP-NOT-JOINING-TO-7720-CONTROLLER/m-p/443650#M82429
If that is the case, you need some specific design help, because merging two controllers into one and getting all of your access points to discover two different controllers on a different subnet will require decisions, planning and downtime.  Do you have a local Aruba SE or Aruba VAR/Reseller that you can contact?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Can you provide the remort support..?
I cannot provide remote support, but I can give advice on this forum.
If you have a support contract, you can contact technical support here:  https://www.arubanetworks.com/support-services/contact-support/
or you could contact your local Aruba Sales Team for advice.
actually i don't have aruba support contract that's why i'm here.
Ok.
Based on the info you gave us, you would have to in general:
1 - Configure your Controllers as a master/local pair
2 - Configure a VRRP between those controllers
3 - Configure discovery for your access points and point them to the VRRP between your controllers
If you have two controllers and have 530 access points, how are they discovering the individual controllers now?
