Does anyone know the latest software available for the 800 series controller? Cant seem to find it.
800 controllers (also 200 and 2400) can run up to 5.0.x code. The latest 5 code is 5.0.4.11.
Hello - New to the WIFI world/aruba. What else is needed to be able to support a/b/g/n? I have the A800 controller and AP 105. License? - Thanks!
The AP105 is an 802.11abgn AP and in order for you to attach to a controller you need an AP license per AP and if you would like to have the firewall module you also need an PEF license per AP
Thanks for the reply. Is there any set of commands that would tell me if I have the license already in place?
You can do the following:
show licenses - It will show all the licenses installed
show ap license-usage - And this one will tell the usage against the licenses you have installed
