3vi
Occasional Contributor I
ADP problem
On a Aruba 730 I'm traing to connect the AP. I manualy set the ip address on the Ap. The Ap ip is on the same subnet of the controller. After boot the ap don't discover the controller and it elect itself to a master. I also connect the ap to same switch of the controller but the same result. The adp on the controller is enable. Is there some firewall rule on the controller that block the join ? Is there some debug ?
Re: ADP problem
Server discovery only happens with DHCP.  You need to set the server ip address manually when you use a static ip address...
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
