AP-105 Channel Quality
I have an AP-105 that is showing a channel quality of 1 on 2.4Ghz.    Any suggestions on where to look at what might be causing it?  It's been this way for a couple days now.   In fact the quality seems to have dropped to 0 at some point today.
Thanks!
Re: AP-105 Channel Quality
Trusted Contributor I
What's the channel utilization at?
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Sorry, was responding from the mobile app which didn't load the image.
Could be juse a display bug as all the other measurements look good. Can you reboot the AP?
After restarting the AP it came back with the same channel quality but changed shortly after.
Thanks!
