Occasional Contributor I
AP-105 gets ip and sees controller address via ADP but not listed in Controller interface?
Sorry, I'm new to this and having an issue setting up AP-105 wireless access points.
I have set a vlan for the 800 controller and can get to the controller configuration interface. The AP's boot and get an IP address and see the controlller via ADP but do not show up in the Controller interface. I'm probably missing something simple. Any assistance would be appriciated.
Re: AP-105 gets ip and sees controller address via ADP but not listed in Controller interface?
Please post the console output from the AP when you are booting it up.
What version of AOS is running on the 800 controller, and is CPSec enabled?
Jerrod Howard
Here is the output the controller has a very old OS
APBoot 1.2.4.4 (build 26618)
Built: 2011-01-07 at 13:42:04
Model: AP-10x
CPU: AR7161 revision: A2
Clock: 680 MHz, DDR clock: 340 MHz, Bus clock: 170 MHz
DRAM: . 128 MB
POST1: mem 0 mem 1 mem 2 mem 3 passed
Copy: ....    done
Flash: 16 MB
PCI: scanning bus 0 ...
dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
00 00 168c 0029 00002 01 10000000 00000000 00000000 00000000
01 00 168c 0029 00002 01 10010000 00000000 00000000 00000000
Net: eth0
Radio: ar922x#0, ar922x#1
Hit <Enter> to stop autoboot: 2  1  0
Checking image @ 0xbf100000
Invalid image format version: 0xffffffff
Checking image @ 0xbf800000
eth0 up: 100 Mb/s full duplex
DHCP broadcast 1
checksum bad
DHCP broadcast 2
DHCP IP address: 192.168.1.9
DHCP subnet mask: 255.255.255.0
DHCP def gateway: 192.168.1.1
DHCP DNS server: 192.168.1.1
DHCP DNS domain:
ADP multicast 1
Controller address: 192.168.1.99
Using eth0 device
TFTP from server 192.168.1.99; our IP address is 192.168.1.9
Filename 'mips32.ari'.
Load address: 0x2000000
Loading: *####################################################
done
Bytes transferred = 3353836 (332cec hex)
Image is signed; verifying checksum... passed
Signer Cert OK
Policy Cert OK
RSA signature verified.
Automatic boot of image at addr 0x02000000 ...
ELF file is 32 bit
Loading .text @ 0x80e00000 (3284968 bytes)
Clearing .bss @ 0x81121ff0 (16 bytes)
Loading .data @ 0x81122000 (32 bytes)
## Starting application at 0x80e00000 ...
Uncompressing..............................
ü
Aruba Networks
ArubaOS Version 3.4.3.2 (build 25931 / label #25931)
Built by p4build@cyprus on 2010-11-02 at 15:59:20 PDT (gcc version 3.4.3)
Cache parity protection disabled
Using 340.000 MHz high precision timer. cycles_per_jiffy=680000
Memory: 123776k/131072k available (1611k kernel code, 7212k reserved, 444k data, 2576k init, 0k highmem)
available.
detected lzma initramfs
initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=13119488
LZMA initramfs by Ming-Ching Tiew <mctiew@yahoo.com> .........................................................................................................................................................................................................
AR7100 GPIOC major 0
wdt: registered with refresh
Enabling Watchdog
Creating 1 MTD partitions on "ar7100-nor0":
0x00000000-0x01000000 : "flash"
i2c /dev entries driver
i2c-talisker: using default base 0x18040000
AD7416 driver probing for devices on AR7100 I2C
Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
Starting Kernel DES KAT ...Completed Kernel DES KAT
Starting Kernel AES KAT ...Completed Kernel AES KAT
No panic info av ailable
<4>ag7100_mod: module license 'unspecified' taints kernel.
AG7100: Length per segment 512
AG7100: Max segments per packet 4
AG7100: Max tx descriptor count 400
AG7100: Max rx descriptor count 252
AG7100: fifo cfg 3 018001ff
AG7100CHH: Mac address for unit 0
AG7100CHH: d8:c7:c8:ce:af:a1
ATHRF1: Port 0, Neg Success
ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 0
AP xml model 39, num_radios 2 (jiffies 1797)
init_asap_mod: installation:0
radio 0: band 1 ant 0 max_ssid 8
radio 1: band 0 ant 0 max_ssid 8
asap_gre_init: ADDED GRE protocol c009e5e8
ath_hal: 0.9.17.1 (AR5416, REGOPS_FUNC, PRIVATE_DIAG, WRITE_EEPROM, 11D)
ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
ath_dfs: Version 2.0.0
Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
ath_pci: 0.9.4.5 (Atheros/multi-bss)
wifi0: Base BSSID d8:c7:c8:6a:fa:18, 8 available BSSID(s)
edev->dev_addr=d8:c7:c8:ce:af:a1
wifi0: AP type AP-105, radio 0, max_bssids 8
wifi0: Atheros 9280: mem=0x10010000, irq=49 hw_base=0xb0010000
wifi1: Base BSSID d8:c7:c8:6a:fa:10, 8 available BSSID(s)
wifi1: AP type AP-105, radio 1, max_bssids 8
wifi1: Atheros 9280: mem=0x10000000, irq=48 hw_base=0xb0000000
net.aruba_asap.br_init = 1
Getting an IP address...
ag7100_ring_alloc Allocated 4800 at 0x8055a000
ag7100_ring_alloc Allocated 3024 at 0x86a8b000
AG7100: cfg1 0xf cfg2 0x7014
ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 3100
AG7100: unit 0 phy is up...RGMii 100Mbps full duplex
AG7100: pll reg 0x18050010: 0x1099 AG7100: cfg_1: 0x1ff0000
AG7100: cfg_2: 0x3ff
AG7100: cfg_3: 0x18001ff
AG7100: cfg_4: 0xffff
AG7100: cfg_5: 0x7ffef
AG7100: done cfg2 0x7115 ifctl 0x10000 miictrl 0x12
Writing 4
192.168.1.9 255.255.255.0 192.168.1.1
Running ADP...Done. Master is 192.168.1.99
<<<<< Welcome to the Access Point >>>>>
~ # Kernel watchdog refresh ended.
Hi Its running a very old OS 3.4.3.2 which is before CPSEC was enabled. Isuspect i need to upgrade the OS
Is 192.168.1.99 the Controller?  Type "show ap database" on the controller commandline to see the status of that AP.  Also, type "show log system 50" to see if you see anything about that AP...
DB shows no AP's attached
show log system 50 output
uba 800) #show log system 50
l 5 11:53:00 :315382: <CRIT> |fpapps| Reboot Cause: Power Failure.
l 5 11:53:04 KERNEL: klogd started: BusyBox v0.60.4 (2010.11.02-23:44+0000)
l 5 11:53:04 KERNEL: Aruba Networks Model A8xx
l 5 11:53:04 KERNEL: ArubaOS Version 3.4.3.2 (build 25931 / label #25931)
Jul 5 11:53:04 KERNEL: Built by p4build@cyprus on 2010-11-02 at 16:48:25 PDT (
c version 3.4.1)
l 5 11:53:04 KERNEL: Copyright (c) 2002-2010, Aruba Networks, Inc.
Jul 5 11:53:04 KERNEL: i2c-dev.o: Registered 'System I2C Interface' as minor 0
l 5 11:53:04 KERNEL: VFS: Disk change detected on device ide0(3,3)
Jul 5 11:53:09 :399816: <ERRS> |fpapps| Initializing the Line Card for Caberne
1
Jul 5 11:53:09 :399816: <ERRS> |fpapps| Initializing the Cabernet STD Port Ca
backs
Jul 5 11:54:11 :313078: <ERRS> |fpapps| XSec Vlan Interface 4095 not found lin
877
877
l 5 11:54:11 :313256: <WARN> |fpapps| Route resolve returned an Error
l 5 11:54:25 :325022: <ERRS> |authmgr| Bogus VLAN ID:4095 received.
--More-- (q) quit (u) pageup (/) search (n) repeat
Jul 5 11:54:36 :304001: <ERRS> |stm| Unexpected stm (Station managment) runtim
error at data_path_handler, 579, data_path_handler: recv - Network is down
Jul 5 11:55:00 :303022: <WARN> |AP d8:c7:c8:ce:f1:1e@192.168.1.2 nanny| Reboot
eason: No reboot message found.
Jul 5 11:55:25 :303022: <WARN> |AP d8:c7:c8:ce:af:a1@192.168.1.9 nanny| Reboot
Jul 5 12:00:24 :303022: <WARN> |AP d8:c7:c8:ce:f1:1e@192.168.1.2 nanny| Reboot
Reason: AP rebooted Sat Jul 5 03:59:29 PDT 2014: SAPD: Unable to contact switch
Called by sapd_hello_cb:4
Jul 5 12:00:51 :303022: <WARN> |AP d8:c7:c8:ce:af:a1@192.168.1.9 nanny| Reboot
Reason: AP rebooted Sat Jul 5 03:59:56 PDT 2014: SAPD: Unable to contact switch
Hope this helps
What is the output of "show ap-group default" and "show ap system-profile default"?
Hi
Output of commands as requested
ruba 800) #show ap-group default
group "default"
rameter Value
rtual AP N/A
2.11a radio profile default
2.11g radio profile default
red AP profile default
hernet interface 0 link profile default
hernet interface 1 link profile default
system profile M3
2.11a Traffic Management profile N/A
2.11g Traffic Management profile N/A
gulatory Domain profile default
Optimization profile default
Event Thresholds profile default
S profile ids-low-setting
sh Radio profile default
sh Cluster profile N/A
uba 800) #show ap system-profile default
system profile "default"
rameter Value
S IP N/A
ckup LMS IP N/A
S Preemption Disabled
S Hold-down Period 600 sec
ster controller IP address N/A
D operating mode (AP-10x/12x only) normal
Band g
uble Encrypt Disabled
tive VLAN ID 1
P MTU N/A
otstrap threshold 8
quest Retry Interval 10 sec
ximum Request Retries 10
epalive Interval 60 sec
mp Server N/A
lnet Disabled
MP sysContact N/A
protect Server IP N/A
protect Backup Server IP N/A
roScout RTLS Server N/A
LS Server configuration N/A
artbeat DSCP 0
ssion ACL N/A
rporate DNS Domain N/A
intenance Mode Disabled
What is the output of "show ap sytem-profile M3"?
