last person joined: 8 hours ago
AP 105 not working in bridge mode
  • 1.  AP 105 not working in bridge mode
    Posted Jan 18, 2012 10:20 AM
    Hello!
    I have two different AP-groups. One for the local segment, and one for a branch office. I use the same AAA-profiles and SSID profiles and everything works fine. But as soon as i try to change in the virtual AP profile for the branchoffice from forward mode tunnel to bridge it stops announcing the SSID. The radios are still up according to the AP. I must have missed something but I can't find what I have missed.
  • 2.  RE: AP 105 not working in bridge mode
    Posted Jan 18, 2012 10:30 AM
    Are you using multiple VLANs in your configuration?  Is the AP connected to a switch port that would drop tagged traffic? In the new AP group you are using did you create a new virtual AP profile?
  • 3.  RE: AP 105 not working in bridge mode
    Posted Jan 18, 2012 02:38 PM
    @discharged wrote:
    Hello!
    Please make sure that you have "Control Plane Security" Enabled, with Auto Cert provisioning on your controller and it is auto-provisioning certificates for your APs.  Local Bridging requires Control Plane Security be on, unless you are provisioning those APs as RAPS.
    (3600.arubanetworks.com) #show control-plane-security
    Control Plane Security Profile
    Parameter                    Value
    Control Plane Security       Enabled
    Auto Cert Provisioning       Enabled
    Auto Cert Allow All          Enabled
    Auto Cert Allowed Addresses  N/A
    WARNING: You can turn on Control plane Security ON if it is off, but it will cause all of your APs to REBOOT and get a certificate (8 minutes outage for LAN-Connected APS).
    (3600.arubanetworks.com) (config) #control-plane-security
    (3600.arubanetworks.com) (Control Plane Security Profile) #?
    auto-cert-allow-all     When enabled, automatic certificate provisioning is
                            allowed on all APs. When disabled, only APs whose IP
                            addresses are in the ranges specified by
                            auto-cert-allowed-addrs are allowed.
    auto-cert-allowed-add.. Range of AP IP addresses allowed for automatic
                            certificate provisioning. Multiple ranges may be
                            specified.
    auto-cert-prov          Enable or disable automatic provisioning of
                            certificates on legacy APs
    cpsec-enable            Enable or disable Control Plane Security
    no                      Delete Command
  • 4.  RE: AP 105 not working in bridge mode
    Posted Jan 18, 2012 06:24 PM
    I read your response and I just enabled it now. (it is midnight where I am). I do not have any AP at my current location but I will test it tomorrow and see if it corrected my problem.
  • 5.  RE: AP 105 not working in bridge mode
    Posted Jan 19, 2012 09:28 AM
    I've had time to test it now and it works! Thanks for the help.
  • 6.  RE: AP 105 not working in bridge mode
    Posted Mar 14, 2012 04:47 PM
    I'm using a Aruba 620 running on 6.1.30. I am able to connect the AP 105 in tunnel mode but as soon as I put it in bridge mode, the radio's will not come up.  The AP does get the DHCP IP address and the the DNS domain name. In the Campus WhiteList tab, I put it to use the factory certificate, but still no success.  Any other ideas?  I do have a separate AP GROUP define as bridge mode.
  • 7.  RE: AP 105 not working in bridge mode
    Posted Mar 14, 2012 04:57 PM
    Type "show ap database" and see if the access point has any flags next to it, indicating why it is not up.
    Also type "show log system 50" to see if it records any errors.
  • 8.  RE: AP 105 not working in bridge mode
    Posted Mar 15, 2012 12:11 PM
    I finally got my AP 105 in bridge mode. It was weird.
    AP GROUP (For bridge mode APs on the VAP settings)
    Controller Plane Security enabled
    Campus Whitelist - mac address is using factory-cert
    AP Provision:
         1. Selected AP GROUP created for bridges APs
         2. Selected No for Remote AP
         3. Host Controller IP Address
         4. Insert AP NAME of access point
         5. Apply
    Thanks Collin for the update.
  • 9.  RE: AP 105 not working in bridge mode
    Posted Mar 19, 2012 10:57 AM
    Question:  Reading the User Guide for 6.1.x,  When configuring the VAP, Forward mode is set to bridge and the Remote-AP Operation by default is standard.  Should I set Remote-AP operation to always or persistent?  Scenerio, location of remote office coming back to the main site via a T1 which would be considered CAP in bridge mode.
  • 10.  RE: AP 105 not working in bridge mode
    Posted Mar 19, 2012 12:19 PM
    You are not configuring that AP as a RAP, so the "remote ap operation" will not come into play.
  • 11.  RE: AP 105 not working in bridge mode
    Posted Oct 01, 2020 08:57 PM
    Sorry I know Im off topic. But I need to post a question about a Aruba Aruba6000-US controller. I cant seem to find anywhere in the community how to do that. Can someone point me in the right direction
  • 12.  RE: AP 105 not working in bridge mode
    Posted Oct 01, 2020 09:04 PM
