last person joined: 8 hours ago
AP 204 Alternatives for VHD with ant-2x2-5314
  • 1.  AP 204 Alternatives for VHD with ant-2x2-5314
    Posted Jun 30, 2016 10:46 AM
    Hi all,
    I am looking to do some testing for a VHD scenario and am looking to use antenna with a 30 degree beamwidth (ANT-2x2-5314), however Ideally I'd like to deploy them with AP-224's to ensure they can handle large numbers of clients. So, my question is - can you do this? What happens with the connection to the 3rd radio chain on the AP? (I'm thinking this would likely be bad.)
    Thanks in advance,
    Jon.
  • 2.  RE: AP 204 Alternatives for VHD with ant-2x2-5314
    Posted Jun 30, 2016 10:56 AM
    We need more information to determine if that is worthwhile or not.
    Is this indoors our outdoors?
  • 3.  RE: AP 204 Alternatives for VHD with ant-2x2-5314
    Posted Jun 30, 2016 11:02 AM
    Thanks for the swift response,
    I am looking to deploy one AP on each 5 GHz channel within a vaguely circular internal space. I'm not yet convinced that I need ot use such narrow beams, but I'd like to know if I have that option.
    So, really I just need to know if this is crazy, or sensible... and if crazy, what the next best thing would be?
  • 4.  RE: AP 204 Alternatives for VHD with ant-2x2-5314
    Posted Jun 30, 2016 11:10 AM
    What is the square footage of the space and how many users are you trying to support?  a Directional antenna does not help or work in an inside space.
  • 5.  RE: AP 204 Alternatives for VHD with ant-2x2-5314
    Posted Jun 30, 2016 11:15 AM
    Thanks for the input Colin but, could you answer the question please - if you know the answer off-the-top-of-your-head. I'm not looking for advice about the 'bigger picture' or design principles at this time.
    My guess is - You can't just leave one of the radios of a 2x4 AP unconnected to an antenna as it is still a receiver itself and you can't disable the single radio.... therefore you should consider using an alternative antenna?
    Jon.
  • 6.  RE: AP 204 Alternatives for VHD with ant-2x2-5314
    Posted Jun 30, 2016 11:45 AM
    Best practice is to use ANT0 and ANT1, and put a 50ohm RPSMA terminator on ANT2. Then you need to disable the 2.4GHZ radio. You will only get 2stream MCS rates.
  • 7.  RE: AP 204 Alternatives for VHD with ant-2x2-5314
    Posted Jun 30, 2016 11:49 AM
    To answer the more broad question, the use case for such a narrow antenna indoors is only for HD LPV where you need small cell coverage from the ceiling to the floor, otherwise it's not a good solution. You can use a 2x2 AP on a 3x3 or 4x4 AP so long as you terminate unused AP connectors.
    Also of interest is we will be releasing a 30deg outdoor 4x4 30deg 5Ghz antenna. When that released you can use that antenna with a 224 or 3x4 AP and use all chains. I think release for antenna is July.
  • 8.  RE: AP 204 Alternatives for VHD with ant-2x2-5314
    Posted Jun 30, 2016 11:51 AM
    Ah, Perfect - thanks!
    Looking forward to that 4x4 antenna - that's probably what i'll end up installing if the project gains traction (and the design works!)
  • 9.  RE: AP 204 Alternatives for VHD with ant-2x2-5314
    Posted Jun 30, 2016 04:13 PM
    Part number will be ANT-4x4-5314. July or Aug price list I believe. Alot of it depends on how long it takes to certify against our APs.
  • 10.  RE: AP 204 Alternatives for VHD with ant-2x2-5314
    Posted Jul 01, 2016 09:10 AM
    One more thought occurs - Do you know if i need a male or female RPSMA Terminators?
