HI,i have to mount an ap-215 to the wall.I need to know what is the ideal height to positioning of the AP.
on datasheet I don't find this information.
RegardsAndrea Acampa
vertical orientation.
Regards
Andrea Acampa
You will need to figure this out based on what you are trying to do. Keep in mind the AP has a downtilt onmi antenna and you will need to account for that. We always recommend mounting on a 90 degree angle bracket if possible, even if you are close to the edge of your facility. Threaded rod is more time consuming but also a possibility.
