last person joined: 4 hours ago
AP 225 HT WLAN mode on 5GHz radio
  • 1.  AP 225 HT WLAN mode on 5GHz radio
    Posted Jul 23, 2015 10:00 AM
    I currently have a solid amber light on my 5GHz LED, and according to Aruba documentation this means that it's in non HT WLAN mode.  What config changes do I need to make to place it in HT WLAN mode?  I've already enabled Very High Throughput in the High-throughput SSID profile, but that doesn't seen to work.  Any suggstions?
    #AP225
  • 2.  RE: AP 225 HT WLAN mode on 5GHz radio
    Posted Jul 23, 2015 10:56 AM
    Did you check under the RF profile ?
  • 3.  RE: AP 225 HT WLAN mode on 5GHz radio
    Posted Jul 24, 2015 09:37 AM
    Yes, everthing HT is checked, yet the 5 GHz light remains amber.
  • 4.  RE: AP 225 HT WLAN mode on 5GHz radio
    Posted Jul 24, 2015 10:03 AM
    if you do a show ap active | include <ap name>, what do you see ?
    11a Ch/EIRP/MaxEIRP
     AP:HT:140/15/22.5
  • 5.  RE: AP 225 HT WLAN mode on 5GHz radio
    Posted Jul 29, 2015 07:49 PM
    Here's the output from the show ap active cmd
  • 6.  RE: AP 225 HT WLAN mode on 5GHz radio
    Posted Jul 29, 2015 08:04 PM
    The entire a radio is disabled on that access point.
