Contributor I
AP-225 - two ethernet interface scenario
I would like to configure two independent network: for employee and guest. I have two independent WAN connection so I would like to assign ETH0 interface to first WAN connection. This interface will be dedicated for employee. ETH 1 interface will be assigned to second WAN and dedicated for guest network. Is it possible using AP and controller or only IAP. If yes, how should I configure it?
Thanks in advance!
Mathew
Re: AP-225 - two ethernet interface scenario
If you have a controller, the best bet would be to hook the second leg into
the controller, not the AP.
Tim Cappalli | Aruba Security
Contributor I
How about IAP? Is it possible to do it without controller?
Mathew
Contributor I
Anybody help me resolve this issue?
Matthew0306,
That scenario is not supported.
