Occasional Contributor I
AP 225 with DC adapter in non-HT WLAN mode
AP 225 is non-HT WLAN mode when powered with DC adapter (12v, 2А). When connected with POE everything OK.
What can be wrong? Any settings have to add?
40:e3:d6:c5:fd:22# sh ver
ArubaOS (MODEL: 225), Version 6.4.2.6-4.1.1.6
Website: http://www.arubanetworks.com
Copyright (c) 2002-2015, Aruba Networks, Inc.
Compiled on 2015-05-12 at 10:54:20 PDT (build 50009) by p4build
AP uptime is 1 hour 7 minutes 16 seconds
Reboot Time and Cause: unknown
40:e3:d6:c5:fd:22#
Sergey.
Re: AP 225 with DC adapter in non-HT WLAN mode
Even if there was not enough power, the 5ghz will always operate with no restrictions.
If there were power restrictions, the 2.4ghz band would operate at 1x1 and the USB would be disabled.
What indication do you have that it is operating in low power mode?
Hi Joseph! Thanks you for reply.
5GHz Amber - Steady. No SSID VOTE seen by clients.
2.4GHz  Amber - Steady. No SSID VOTE seen by clients.
I've attached full config txt file.
Thanks!
Sergey.
The config will not say anything. Please PM me the tech support.
Joseph,
See attach please.
regards,
Sergey.
Sir,
Your AP did not get an ip address.  Is there any way to have DHCP supplied to that AP?
Joseph,
This AP is in the standalone application used. Just to connect some laptops via WIFI.
regards,
Sergey.
Okay.
I would consider upgrading the AP to the latest GA code.  It is currently showing errors on the wireless interface.
Specifically I see these errors below and they have nothing to do with power.  Please try to upgrade to the latest GA code here:  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/Default.aspx?EntryId=20377
verflows!
[51182.200549] wl1: 11 rx fifo 0 overflows!
[51184.675750] wl1: 4 rx fifo 0 overflows!
[51187.380743] wl1: 2 rx fifo 0 overflows!
[51201.627339] wl1: 6 rx fifo 0 overflows!
[51210.843277] wl1: 6 rx fifo 0 overflows!
[51215.238087] wl1: 3 rx fifo 0 overflows!
[51217.379964] wl1: 1 rx fifo 0 overflows!
[51220.478384] wl1: 2 rx fifo 0 overflows!
[51231.611435] wl1: 12 rx fifo 0 overflows!
[51244.357492] wl1: 10 rx fifo 0 overflows!
[51247.379963] wl1: 2 rx fifo 0 overflows!
[51251.898548] wl1: 1 rx fifo 0 overflows!
[51257.814441] wl1: 4 rx fifo 0 overflows!
Joseph,
I've upgraded AP but I have the same problem.
ArubaOS (MODEL: 225), Version 6.4.2.6-4.1.1.11
Compiled on 2015-11-22 at 16:41:06 PST (build 52666) by p4build
AP uptime is 20 minutes 41 seconds
40:e3:d6:c5:fd:22#
New tech-support attached.
Sergey.
