AP-228 questions
  • 1.  AP-228 questions
    Posted May 13, 2015 09:21 AM
    Does the AP-228 take AC adapter power? Or is POE the only option?
    Also, is there an outdoor omni dual frequency antenna available for this? Or do I need to use a separate 2.4GHz and 5GHz antennas?
    Mike
  • 2.  RE: AP-228 questions
    Posted May 13, 2015 09:27 AM
    PoE
    <EDIT: removed. 274 also has 6 connectors>
  • 3.  RE: AP-228 questions
    Posted May 13, 2015 09:52 AM
    There is no AC power option for the AP-228; POE (802.3at) or injector only.
    You'll need a separate antenna(s) for each band.
