Contributor II
AP-275 802.11n standard issue
Can AP-275 use 5GHz for 802.11n standard or only 802.11ac?
Duc Nguyen
Re: AP-275 802.11n standard issue
Yes, simply disable VHT in the radio and arm profiles.
Tim
Tim Cappalli | Aruba Security
Aruba
In addition to Tim's response, all 802.11ac APs are backwards compatible and will fully support 802.11a,b,g,n clients and standards even without disabling VHT.
AMFX | ACCX | ACDX | ACMX
