Hi
I am running an IAP cluster with multiple APs.
Is this setting enforced per AP, so if one AP has a broken uplink it will disable the SSIDs?
Also what is the difference:
n Uplink down -> which one
n Internet down -> which IP/DNS is pinged at which interval?
n Primary uplink down -> ??
What i want to avoid is that the SSID is totaly disabled if only some of the APs have problems.
Best,
Thomas
