What is a realistic distance for the AP-375 ? I was told 200m. Trying to find solid documentation on this.
The area I am trying to cover is flat and open without obstructions.
https://www.arubanetworks.com/products/networking/access-points/370-series/
It really depends on Signal Strength.
I tried with AP-275 in Ekahau
At -69dbm, you can get 200m.
Tx Power on Access Point was 25mW
Kapil
I found the chart below.
Assuming the below I would have a datarate of 216 at -71 or 108 at -76.
Does this sound accurate ? Any thoughts?
The only caveat I see with that chart is that the MCS rates shown indicate 4 spatial streams. In an outdoor environment, 4 spatial streams may be difficult to support at range.
200m range from a 375 is easily doable with clear line of sight (that is our design margin criteria for outdoor). We've done 600m to a MPB in wide open space. Environment (pathing, noise, etc) all come in to play though. 200m is pretty easily doable though in most all but the worst environments.
