AP-375 won't join Wireless Manager
Good afternoon all,
I'm trapped into an issue which I'm unable to sort it out.
Our environment has a redundant 7205 Wireless Manager running 8.3.0.1.
I have a bunch of AP-304 and AP-305 that works fine. I had to add additional AP to our env, in particular AP-375 outdoor. I would expect that AP would join WM automatically as other AP has done but it wasn't.
Then I connect to the serial console and forced AP conversion via cmdline specifying CAP mode and WM VRRP ip address.
Then AP download the new firmware and reboots. Once it boots then it stops at:
[ 56.917838] br0 address=80:8d:b7:cf:58:7c
[ 56.965760] wifi0: AP type AP-375, radio 0, max_bssids 16
[ 57.030365] aruba_mods_radio_attach() INT setting antenna polarization to 1 radio 0
[ 57.123117] Resetting spectral chainmask to Rx chainmask
[ 57.187191] Init the PCAP for radio0 offload 1.
[ 57.241080] aruba_mods_radio_attach: radio: 0, init txq work cpu: core-0
[ 57.337675] pktlog_init: Initializing Pktlog for AR900B, pktlog_hdr_size = 16
[ 57.412621] pktlog_init: Initializing Pktlog for AR900B, pktlog_hdr_size = 16
AP rebooted Thu Jan 1 08:16:13 UTC 1970; System cmd at uptime 0D 0H 16M 26S: Image Upgrade Successful
shutting down watchdog process (nanny will restart it)...
<<<<< Welcome to the Access Point >>>>>
On WM no AP appears to be provisioned. After 60-70 secs AP reboots to factory image.
Does anybody has some suggestions?
Thank you
Davide Bortolini
Re: AP-375 won't join Wireless Manager
Thanks for the update on the firmware version running on the mobility controller (8.3.0.1 vs 8.0.3.1). That addresses the first concern.
Can you attach the full console log from the AP-375 booting up? Specifically, I'm looking for the part where the AP gets an IP address and then does master discovery to try and find the controller to connect to.
The AP-375 will behave a little differently than the AP-300 series, as it is a single image universal image that can run in either Instant or controller based architectures, depending on what it discovers during boot up. Since it appears the AP did discover your mobility controller in order to update code, those boot details will help diagnose further what is going on.
Charlie Clemmer
Aruba Customer Engineering
Hi Charlie,
here you will find the full console log captured BEFORE and AFTER the AP conversion to managed AP. It boots the same Wireless Manager Version but stops at # prompt. Then it rebbots automatically to factory after 60-70 secs.
Davide Bortolini
Thanks for the logs. Is CPSec enabled in this environment, and has the new AP-375 been added to the whitelist so that it can communicate with the controller?
Charlie Clemmer
ADP is disabled by uap_controller_less
Please see the thread here:  http://community.arubanetworks.com/t5/Controllerless-Networks/CAP-back-to-IAP-on-Mobility-Controller/m-p/298618
Hi Charlie,
yes the CPSec is enabled and the AP is whitelisted. I have tried as well as to disable UAP controller less env but same issue.
I have also captured the datapath table once the AP is booted after conversion.
(W11NWLAC01) [mynode] #show datapath session table 10.11.48.105
Q - Real-Time Quality analysis
u - Upstream Real-Time Quality analysis
E - Media Deep Inspect, G - media signal
r - Route Nexthop, h - High Value
A - Application Firewall Inspect
B - Permanent, O - Openflow
L - Log
Source IP Destination IP Prot SPort DPort Cntr Prio ToS Age Destination TAge Packets Bytes Flags CPU ID
10.11.48.253 10.11.48.105 17 514 54462 0/0 0 0 0 pc0 9 0 0 FY 11
10.11.48.105 10.11.48.253 17 54462 514 1/15785 0 0 1 pc0 9 1 216 FC 11
No way to hook it up. It still reboots.
Thank you
Davide Bortolini
Is there anything interesting in the mobility controller's log?
show log system 50
Charlie Clemmer
Hi Charlie,
thi is what I captured from system log just after issuing AP converion command and rebooted it.
Aug 9 20:23:40 KERNEL(APBNU02@10.11.48.16): [15306.132105] DFS min filter rssiThresh = 15
Aug 9 20:23:40 KERNEL(APBNU02@10.11.48.16): [15306.132116] DFS max pulse dur = 61 ticks
Aug 9 20:23:40 KERNEL(APBNU02@10.11.48.16): [15306.132124] DFS max pulse pri = 5004, min pulse pri = 246
Aug 9 20:23:40 KERNEL(APBNU02@10.11.48.16): [15306.132162] dfs_radar_enable: firpwr=0, rssi=0, height=0, prssi=0, inband=0, relpwr=0, relstep=0, maxlen=0
Aug 9 20:23:40 KERNEL(APBNU02@10.11.48.16): [15306.132171] Enabled radar detection on channel 5260
Aug 9 20:23:40 KERNEL(APBNU02@10.11.48.16): [15306.132179] dfs_radar_enable: duration multiplier is 72
Aug 9 20:26:34 :303022: <WARN> |AP 80:8d:b7:cf:57:be@10.11.48.21 nanny| Reboot Reason: AP rebooted Thu Jan 1 08:15:47 UTC 1970; System cmd at uptime 0D 0H 16M 2S: Image Upgrade Successful
Aug 9 20:28:36 :311002: <WARN> |AP 80:8d:b7:cf:57:be@10.11.48.21 sapd| Rebooting: SAPD: UAP controller less
Aug 9 20:28:37 :303086: <ERRS> |AP 80:8d:b7:cf:57:be@10.11.48.21 nanny| Process Manager (nanny) shutting down - AP will reboot!
Davide Bortolini
There's not enough information from the log entries to show the AP-375 attempting to connect. The datapath output you provided shows the AP sending syslog to the controller (port 514), but there is no PAPI for control plane. The AP and controller are on the same subnet, so unless there's a layer 2 firewall blocking traffic, there should not be anything keeping a whitelisted AP from joining.
Two thoughts. The AP-375 is not trying to come up as a mesh point, correct?
What is the current license state on your controller?
show ap license-usage
Are there enough valid licenses available for the new AP to join the controller?
Charlie Clemmer
Hi Charlie,
that's exactly our issue. AP won't come as mes point.
What drives me crazy is that I have this issue ONLY with AP-375 (I have 5 of them and no one joins the controller). The behavior is the same: connect to WLC, get latest firmware, reboot and try to connect, then reboot in factory mode. I have already joined several 304 and 305 models with no issues.
Below there's my license info:
(W11NWLAC01) [mynode] #show ap license-usage
AP Licenses
Type Number
AP Licenses 60
PEF Licenses 60
Controller License True
Overall AP License Limit 60
AP Usage
Type Count
Active CAPs 17
Active RAPs 0
Remote-node APs 0
Tunneled nodes 0
Total APs 17
Remaining AP Capacity
Type Number
CAPs 43
RAPs 43
Thank you again for your support.
Davide Bortolini
