Occasional Contributor I
AP MIMO with single Antenna connected
HI to all,
can I install MIMO AP (AP204) just with one antenna  connected on a single RF connector?
If yes, what is the impact on the performance.
Thanks for your support and cooperation.
Best Regards
Re: AP MIMO with single Antenna connected
Mimo gets its performance from multiple antennas.  You would be risking significantly poor performance.
You also must provision the AP for single-chain. The user guide has some details on that as well as which antenna connector must be used.
Jerrod Howard
