Frequent Contributor I
AP Need to Reboot to Get Connected to Wifi
We are getting an issue that client cannot connect to open guest ssid. After reboot the AP,then client can connect to the ssid.Is there any possible cause?any related to firmware issue?yesterday need to use spare ap than able to connect.This is hotel deployment.2 rooms will share 1 AP.They are using AP93 and AP105.Controller firmware is 6.4.2.3.
Re: AP Need to Reboot to Get Connected to Wifi
We don't have enough information to determine that.
Do you have "broadcast filter all" enabled on your virtual APS"?
Hi Colin,
Yes all broadcast filter enable include deny broadcast probes.
Regards,Amir
Can I have a screenshot of Dashboard> Performance?
