Split-tunnel is not available in campus mode.
When the APs are configured as RAPs, you can configure the SSID to stay up if the controller goes down, but it would depend on if you’re using PSK vs open vs 802.1X.
Bridge mode campus APs require a controller to be available.
Remote-AP Operation | Configures when the virtual AP operates on a remote AP: l always—Permanently enables the virtual AP (Bridge Mode only).No authentication supported. l backup—Enables the virtual AP if the remote AP cannot connect to the controller(Bridge Mode only).No authentication supported. l persistent—Permanently enables the virtual AP after the remote AP initially connects to the controller (Bridge Mode only). l standard—Enables the virtual AP when the remote AP connects to the controller.Use standard option for tunneled, split-tunneled, and Bridge SSIDs. Note: Only open/PSK security mode is allowed for always/backup RAP operation. No authentication is supported for always/backup. |
