AP discovery issue
  • 1.  AP discovery issue
    Posted Apr 04, 2016 09:02 AM
    Hi there,
    I got a new issue and I am not sure what to do.
    I have been added a new batch of APs (after renovation ) and noticed that all the newly added APs are not discovered by the controller.
    When I check the adp  i get :
    (VNR557WLC01) #show adp config
    ADP Configuration
    key        value
    discovery  enable
    igmp-join  enable
    igmp-vlan  0
    all the APs are getting an IP and I can ping them from the master
    #ping 10.128.18.242
    Press 'q' to abort.
    Sending 5, 100-byte ICMP Echos to 10.128.18.242, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 0.735/0.8826/1.108 ms
    However , the master never seen them , so I cannot provision them.
    I am sure I am missing seomehting here. We did this many many times and nerver encounter this situation.
    Thank you for any help you can provide.
  • 2.  RE: AP discovery issue
    Posted Apr 04, 2016 09:04 AM
    ADP requires L2 adjacency. Were you using ADP previously?
  • 3.  RE: AP discovery issue
    Posted Apr 04, 2016 09:07 AM
    @Gerry_uottawa wrote:
    Hi there,
    ADP Configuration
    key        value
    discovery  enable
    igmp-join  enable
    igmp-vlan  0
    #ping 10.128.18.242
    Press 'q' to abort.
    If new APs are not coming up, frequently either (1) DHCP Options are not being set (2) the Domain is not being set in the DHCP options, so DNS-based discovery of aruba-master.<domain>.com will not work.
  • 4.  RE: AP discovery issue
    Posted Apr 04, 2016 09:21 AM
    Well well, each day is full of suprises.
    So basically the discovery is not based on ADP but DCHP and sure enough the Domain was gone  in the DHCP options.
    Thanks for your help.
