Occasional Contributor I
AP's in a Mesh keep rebooting
We have two sites that are linked via two AP 60s with external aerials. These AP's have been setup as a mesh in order to extend the site to another building.
This has been up and running for the past 3 years but now the link between the two sites keeps dropping
When I look at the logs we keep seeing
Oct  9 05:08:55  nanny[139]: <303022> <WARN> |AP Start_Hill_AP@10.233.82.202 nanny|  Reboot Reason: AP rebooted Tue Oct 9 14:07:08 BST 2012: SAPD: Unable to contact switch. Called by sapd_keepalive_cb:4462
Oct  9 05:14:34  nanny[139]: <303022> <WARN> |AP Start_Hill_AP@10.233.82.202 nanny|  Reboot Reason: AP rebooted Tue Oct 9 14:12:26 BST 2012: SAPD: Unable to contact switch. Called by sapd_ap_ready_cb:3142
The Start_Hill AP is connected directly to the controller so we can't understand why it keeps rebooting.
They are running software version 3.4.0.4
Can anyone suggest anything?
Re: AP's in a Mesh keep rebooting
Check the ethernet interface where Start_hill is connected to make sure the AP negotiated the correct speed and duplex on that port.
I have checked the port and it is connected at 100mbs full duplex. The port is set to Auto speed and auto duplex.
There are no errors either.  However the controller was rebooted yesterday and the cabling to the AP changed.
What is between the access point and controller physically?
There are two CAT5 cables that have been run from the AP to the comms room.
At the AP end, the cable is terminated with an RJ45 (so it can plug directly into the AP). At the other end the cables are terminated onto RJ45 sockets and then a patch lead from the socket to the controller.
If the only thing that was changed is the cable, I want to say, please test the cable.
Are you powering the AP with a power injector?  What type and what is the length of the cable?
We only changed the cable in an attempt to fix the problem.
Both AP's are being powered by PoE. The one connected to the controller is using one of the PoE ports on that. The AP is approximately 35mtrs from the controller
The other is getting it's PoE from the network switch installed. This is a distance of approximately 10 mtrs. This switch is also providing PoE to the IP phones installed there.
The phones are using the Mesh to get back to the telephone system at the head office (where the Start_Hill AP is located).
While that access point is connected see if it is missing any heartbeats.  On the commandline, type:
show ap debug system-status ip-addr <ip sddress of ap> | begin Heartbeat
Heartbeat Stats
Heartbeats Sent  Heartbeats Received  Measurement Duration
382489           379275               since last rebootstrap
382489           379275               total since bootup
I have run the command for both AP's and they are saying 0 sent and 0 received
Can you ping the AP from the controller?
What provides DHCP to the AP, or is it statically addressed?
What does the access point use to discover the controller?  DNS, DHCP, Broadcast?
When you type "show ap database", what is the last ip address that the AP ever got?
