AP's not changing channel
  • 1.  AP's not changing channel
    Posted Sep 26, 2013 06:02 AM
    I have 3 AP93's depolyed in a portacabin structure, and they all appear to be on the same channel.
    As far as I can tell, this group of APs is using the same default valuse that other working APs are, so do I need to tweak some settings?  I could assume that perhaps ARM is not working properly, or the 3 APs are simply not seeing each other.
    Cheers
  • 2.  RE: AP's not changing channel
    Posted Sep 26, 2013 07:11 AM
    Are those APs to close to each other ?
    Make sure ARM is on ?
    Are users experiecing performance issues ?
  • 3.  RE: AP's not changing channel
    Posted Sep 26, 2013 09:28 AM
    Are those APs to close to each other ?      Should be close enough to see each other, but not too close
    Make sure ARM is on ?   Yes
    Are users experiecing performance issues ?  Yes, there are definately strange things goin on
    Is it possible to tell from an AP which other APs it is aware of?
  • 4.  RE: AP's not changing channel
    Posted Sep 26, 2013 11:23 AM
    You could run the following command :
    show ap monitor ap-list ap-name <apname>
