AP total down with RED zero
Hello
I am still facing the problem with access point I've changed from 3.3 AOS ro 6.3 AOS
I was able to detect the APs before for a while and next all APs went down
but with 6.3 AOS I have this RED zero !! does this mean anything ?
Thanks in advanced
Regards
Re: AP total down with RED zero
Did you upgrade directly to 6.3? There is a step upgrade process from code
that old.
The red 0 is no different than a black 0.
Tim Cappalli | Aruba Security
thanks for your reply
yes I upgrade from 3.3.2.13 to 6.3.1.5_43118 directly
Regards
You should contact Aruba TAC.
3.3 to 6.3 is not a supported upgrade path.
Did you read the release notes?
could you tell me which version I should update first ? and next to 6.3 ?
also with 3.3 it was the same problem do you have any idea why ?? I posted my configurations on my previous thread in the community
Regards
Please look at the release notes for 6.3. It goes over the upgrade path.
You should also contact Aruba TAC at this point.
ok I will contact them
my purpose from upgrade was to check if I can make APs up all time and stable
I've been in this since few days and nothing work with me
I read a lot of threads on community but nothing works
my core-switch and aruba controller can ping each other and the settings are very simple and I didn't involve too many only the basics and still APs is not detected yet
I hope to find my solution here cause I like the support from this community it is very swift
Regards
I wonder if the APs firmware was upgraded when I upgrade from 3.3 to 6.3 AOS and that is why I can't detect them anymore
cause right now I downgrade to 3.3 and still can't detect them ? does that make any since ?
Contributor I
Can you please console in to the ap and to see what msgs are coming. I would also try to do purgeenv or reset the ap to factory default to see if that helps.
Thank you.
I went back to 3.3 AOS and configured basic configurations and it worked but it took a while to detect the APs but it is okay as long as it is wokring I am working on it now
thanks for all of your support guys
