last person joined: 2 hours ago
AP125 configuration
  • 1.  AP125 configuration
    Posted Jun 19, 2013 11:01 AM
    hi,
    I want to know is there any way I can configure AP125 without using mobility controlller.
    uv.
  • 2.  RE: AP125 configuration
    Posted Jun 19, 2013 11:03 AM
    Is not possible , please read the datasheet
    http://www.arubanetworks.com/pdf/products/DS_AP124-125.pdf
    What are you trying to accomplish ?
  • 3.  RE: AP125 configuration
    Posted Jun 19, 2013 02:38 PM
    Are you trying to configure the AP with a static IP to go back to the controller? I have done this via a console cable, but then it has to report back to a controller.
  • 4.  RE: AP125 configuration
    Posted Jun 20, 2013 07:39 AM
    hi,
    I want to create around 5 configurations for Aruba 125 using Mobillity controller.  I want to remove Mobility controller, and using console of AP125, I want to load any of those profiles whenever needed.  PLease tell me if it is possible, I am not getting this anywhere in the docs.
    thanks in advance.
    uv.
  • 5.  RE: AP125 configuration
    Posted Jun 20, 2013 07:43 AM
    You cannot use the AP125 without the controller, period.
  • 6.  RE: AP125 configuration
    Posted Jun 20, 2013 07:48 AM
    When you say profiles what exactly do you mean ? if you remove the controller the AP125 wont be able to function on it's own
    But if you want to change some of the settings through the console you can .
    You can configure the following:
    - AP-Group that AP will be part of
    - AP name
    - IP address
    See this thread it list some of the commands you can use to configure the AP through the console :
    http://community.arubanetworks.com/t5/Access-Points/printenv-command-on-AP-s/td-p/2420
  • 7.  RE: AP125 configuration
    Posted Jun 20, 2013 10:19 AM
    hi,
    I want to create AP Group like Group1 with SSID, open-none, band A. ; Group2 with SSID, open-wep, band B, 40MHz.  I want the AP to be in any group whenever I want it to.  I want this change to happen without the involvement of mobility controller.
    thanks
    uv.
  • 8.  RE: AP125 configuration
    Posted Jun 20, 2013 10:23 AM
    You can do this through the console by configuring the AP-Group which has all the settings the AP needs :
    setenv group <AP-Group name>
  • 9.  RE: AP125 configuration
    Posted Jun 20, 2013 12:06 PM
    hi,
    When I type 'setenv' in the console it says 'permission denied'.  But the command 'ifconfig' works fine.  please guide me.
    thanks
    uv.
  • 10.  RE: AP125 configuration
    Posted Jun 20, 2013 12:09 PM
    You have reboot the AP and stop the boot process
  • 11.  RE: AP125 configuration
    Posted Jun 20, 2013 12:14 PM
    @ubuntuv wrote:
    hi,
    thanks
    uv.
    To make it very clear:
    You CANNOT configure an AP125 without a controller.  It is not possible to switch profiles or configuration for an AP125 without a controller.  You cannot Operate an AP125 without a controller except under limited circumstances.
