- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AP134 with dual element antenna
09-11-2013 07:33 AM
I would like to be able to connect a dual element antenna to an AP134 (or AP114) and was wondering what connectors to use, if I set MCS to 0-15?
The reasons for this is that the gain and beamwidth I need is only provided by dual-element antennas. I know I can use the AP104, but I'd need separate antennas for each band, and then mounts, lightening arrestors etc.
ACCP, ACCX #817, ACMP, ACMX #294
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: AP134 with dual element antenna
09-11-2013 05:52 PM
Not a recommended/best-practices deployment. Sounds like you already know that of course.
That's a large investment (north of $1K) to get something in place that really isn't ever going to operate at it's full potential.
What are the gain and beamwidth that you need on each Band ?
Perhaps we can brainstorm up an alternative approach.
JF
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
09-11-2013 11:35 PM
I need something like the AP-ANT-18 but an outdoor version with N-type connectors. The AP will be inside with the antenna on the outside of the building.
It will be a mesh portal, meshing with an AP175 but I still need the client coverage, otherwise I'd use the AP92.
Although the AP104 is a good choice, the extra antenna, mount kit and 2 x lightening arrestors makes it more expensive than a single AP134 with antenna.
So, I'm thinking to use the ANT-2X2-D607, but with only two elements, which connectors to use on the AP134 (or AP114) if I can configure it to use only two chains or MCS0-15?
Appreciate the advice.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
09-18-2013 07:31 AM
any ideas on this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
