AP135 Up and Down problem
  • 1.  AP135 Up and Down problem
    Posted Oct 14, 2013 05:39 AM
    I am currently facing these Aruba AP model 135 problem. There are 310 units of them serving by 2 units of 3600 Controllers on Master/Local mode. The 135APs are provisioning into Remote APs with certificate.
    1st unit of controller has 56 license, 2nd unit of controller has 256 license. So i should provision the 310 units of them to 56 units pointing to master, and 254 units pointing to local correct?
    Another problem i am facing is, some of the APs are down and up randomly, they were up for a few hours or few days then they went down and the other unit came up.
    I took a look at the controller's process log it shows something like this:
    Oct 15 13:31:00 sapd[836]: <404074> <WARN> |AP APR-246@10.100.100.98 sapd| AM 6c:f3:7f:56:a3:a0: ARM - increasing power cov-index 8/0 tx-power 3 new_rra 6/4
    Oct 15 13:31:09 sapd[836]: <404074> <WARN> |AP APR-9439@10.100.100.24 sapd| AM 6c:f3:7f:56:bd:20: ARM - increasing power cov-index 4/2 tx-power 3 new_rra 11/4
    Oct 15 13:31:09 sapd[836]: <404050> <WARN> |AP APR-9429@10.100.100.76 sapd| AM 6c:f3:7f:be:9d:d0: ARM C 161 PER 0 MER 90 FRR 0 50-30
    Oct 15 13:31:10 sapd[836]: <404089> <WARN> |AP APR-9429@10.100.100.76 sapd| AM 6c:f3:7f:be:9d:d0: ARM HT Error Threshold Trigger Current Channel old 161-157 new 161-157/7
    Oct 15 13:31:16 sapd[836]: <404075> <WARN> |AP APR-170@10.100.100.74 sapd| AM 6c:f3:7f:bc:19:60: ARM - decreasing power cov-index 9/3 tx-power 6 new_rra 6/5
    Oct 15 13:31:22 sapd[833]: <404075> <WARN> |AP APR-9713-SUITE@10.100.100.94 sapd| AM 6c:f3:7f:be:97:a0: ARM - decreasing power cov-index 10/2 tx-power 4 new_rra 6/3
    The master controller sometime shows this:
    Oct 14 21:49:21 sapd[836]: <404069> <WARN> |AP APR-9407@10.100.100.98 sapd| AM 6c:f3:7f:56:bd:00: ARM Channel Interference Trigger new 11-120 old 6-163 new_rra 11/6 TCI 10
    May i know what is the issue that causing these?
    The switches that are connected by APs are PoE+ supported.
    Thanks for help
    #AP135
    #3600
  • 2.  RE: AP135 Up and Down problem
    Posted Oct 14, 2013 06:24 AM
    Hi :smileyhappy:
    YES. (u may also consider using AOS 6.3.X with centralized licensing.All depends on your configuration,needs,and network topology)
    The logs u sent..arent relevant...your only copied ARM logs....
    if your ap units goes up and down..you should connect console for one of those units and u will be able to see the reboot reason.... Or u can search via cli " show log all | include reboot "
    Me.
