PD-9001GO-NA is AP175 outdoor POE injector
i knew that if injector will be used indoor , we can use indoor injectors with outdoor A175 , is this right ? what will be part nu for this indoor injector that can work with the AP175 ?
Actually, for AP-175P we recommend using a POE+ injector (PD-3501G-Ac is 802.3af basic POE only). The indoor model for that is PD-9001GR-AC.
