AP205 uplink_vlan OS 6.4.2.2 not working
  • 1.  AP205 uplink_vlan OS 6.4.2.2 not working
    Posted Nov 05, 2014 07:23 AM
    hi,
    we are not able to configure our new AP205 with the current setup... AP105 working well
    3 TAGGED VLANs on AP uplink (configured on HP switch) - we configured the uplink_vlan but the AP ignore this setting
    if i set one vlan as UNTAGGED, the AP is properly connected. in smaler offices we are not able to set a UNTAGGED vlan, there we only have the possibility to set one vlan as untagged or several as tagged.
    maybe a bug in 6.4.2.2 and AP205?
    thanks
    #AP205
  • 2.  RE: AP205 uplink_vlan OS 6.4.2.2 not working
    Posted Nov 05, 2014 09:05 AM
    Can you share the config from both AP models?  Have you opened a case?
  • 3.  RE: AP205 uplink_vlan OS 6.4.2.2 not working
    Posted Nov 05, 2014 09:26 AM
    yes, a case is already opened 1608666
    which config? the whole show ap config ap-name?
    both APs are working (205 / 105), however AP205 only when the management VLAN is untagged!
    thanks
