AP324 with external antenna AP-ANT-45
  • 1.  AP324 with external antenna AP-ANT-45
    Posted Mar 03, 2018 09:15 AM
    Hi all,
    I am connecting the external antenna AP-ANT-45 to an access point Aruba AP 324.
    in the provisioning the antenna gain for 2.4 and 5 GHz is required.
    I entered 0 for both 2.4ghz and 5 ghz and there is a good signal from the access point, but i don't know if this is the best or not??!!!
    in my case what is the best value in 2.4ghz and 5 ghz antenna gain(dBi)???
    Thanks in advance
  • 2.  RE: AP324 with external antenna AP-ANT-45
    Posted Mar 03, 2018 09:36 AM
    I think it depends on the antenna. What's the gain on antenna?
  • 3.  RE: AP324 with external antenna AP-ANT-45
    Posted Mar 04, 2018 01:56 AM
    Thanks magnumpi83 for your reply.
    according the data sheet the gains is:
    4.5 dBi for 2.4 ghz and
    5.5 dBi for 5 Ghz.
    but when i put these values the signal is not good as I want, is there anything I can do??
  • 4.  RE: AP324 with external antenna AP-ANT-45
    Posted Mar 05, 2018 07:35 AM
    No, you can't. The maximum transmit power is set by regulatory. Putting lower numbers as antenna gain is a violation of the law.
  • 5.  RE: AP324 with external antenna AP-ANT-45
    Posted Mar 05, 2018 03:53 PM
    Which is why our products require "professional installation".
  • 6.  RE: AP324 with external antenna AP-ANT-45
    Posted Mar 11, 2018 10:06 AM
    thanks for replys.
    but until now I can't know what is the maxium gain that i can put for ap-ant-45
    I need the maximum??
  • 7.  RE: AP324 with external antenna AP-ANT-45
    Posted Mar 11, 2018 02:14 PM
    As noted from the data sheet, the antenna gain is 4.5 and 5.5dBi, respectively. Those are the values that should be used when provisioning the AP, so that the controller can correctly determine EIRP when an AP transmits at a certain power level.
    Setting these values to zero results in the caluculation of a lower EIRP than actual, and could result in the AP transmitting at higher power than legally allowed.
