APs rebooted
  • 1.  APs rebooted
    Posted Nov 08, 2017 11:51 AM
    Hi All,
    For some reason, some access points of my infrastructure rebooted at October 31.
    I got the follow information from one of the APs.
     #show ap debug system-status ap-name APXXXXX
    Reboot Information
    AP rebooted Tue Oct 31 15:24:44 pst 2017; Entering REBINDING state; t1 604768 t2 604800 lease 691200 (saved_ip 172.16.27.46 yiaddr 172.16.27.96 saved_router 172.16.27.254 new_router 172.16.27.254)
    Rebootstrap Information
    Date Time Reason (Latest 10)
    (none found)
    HA Failover Information
    (none found)
    Recent Control Messages from AP to Controller
    Date Time Message Description
    Wed Nov 8 14:22:44 2017(142 secs ago): SENT REQ type=BW_REPORT len=106 peer=172.16.63.80 seq_num=5729 num_attempts=1 rtt=0 secs 0400000065040000000705AC101B60040000006B04000016610400000001040000020804000000030400000002020004000000000400000000040000000004
    Wed Nov 8 14:22:38 2017(148 secs ago): SENT REQ type=BW_REPORT len=106 peer=172.16.63.80 seq_num=5728 num_attempts=1 rtt=0 secs 0400000065040000000705AC101B60040000006B04000016600400000000040000026004000000030400000002020004000000020400000170040000001004
    Wed Nov 8 14:17:44 2017(442 secs ago): SENT REQ type=BW_REPORT len=106 peer=172.16.63.80 seq_num=5727 num_attempts=1 rtt=0 secs 0400000065040000000705AC101B60040000006B040000165F0400000001040000021004000000030400000002020004000000000400000000040000000004
    Rebootstrap LMS
    (none found)
    Do you know what mean Entering REBINDING state on this log?
    Thank you
  • 2.  RE: APs rebooted
    Posted Nov 08, 2017 02:05 PM
    I'm not sure, but could it be normal behaviour when the AP gets a new IP from DHCP it needs to reboot? When assigninging a statical address it needs to have a reboot for sure...
  • 3.  RE: APs rebooted
    Posted Nov 08, 2017 02:13 PM
    Correct, but the APs are operating with Dynamic IP Address and they have not been reprovisioned in this period.
  • 4.  RE: APs rebooted
    Posted Nov 08, 2017 02:53 PM
    Could you check one of the other rebooted AP's if the same message appears? 'Rebinding' means that it got a new lease from your DHCP.
    Old address 172.16.27.46 new address 172.16.27.96.
  • 5.  RE: APs rebooted
    Posted Nov 09, 2017 06:04 AM
    I suspected that, too.
    Yes. The others APs rebooted for the same reason.
