APs will not connect after an upgrade to 6.1
Good Afternoon,
I am having trouble with a controller which i just upgraded to 6.1.  I believe I found the solution below in this article, but I'm not sure how to do what this article describes.  Any help isgreatly appreciated.
https://arubanetworkskb.secure.force.com/pkb/articles/Troubleshooting/R-1205
Thanks!
Re: APs will not connect after an upgrade to 6.1
Please be more specific.  What did you upgrade from and to, and what type of access points do you have?
hi
i'm new here, jsut want to know is it possible ap 125 to run AOS 6.1?
Yes.
I found the error.  It was a typo in the gateway address for the VLAN I had setup for the APs.
Dyslexia had taken over that day and I had transposed a couple of digits.
Thanks for the help!
Awesome!
