ARUBA 650 BRANCH OFFICE MOBILITY CONTROLLER
  • 1.  ARUBA 650 BRANCH OFFICE MOBILITY CONTROLLER
    Posted Apr 30, 2013 11:04 AM
    i have just deployed the above controller in a hotel.
    Everything is working fine, but i have a few questions to ask.
    Intermitantly user using various devices complain that they cannot get onto the wifi network. They see the SSID and try to login.
    They eventually time and without being able to connect.
     Is there a issue or compatabiltiy issue with some wifi products.
    to cure this i have to reset the controller and 9/10 times it resloves the issue.
    the system has 6.1.3.0 sw installed , is this and issue ?
    thanks in advance.
  • 2.  RE: ARUBA 650 BRANCH OFFICE MOBILITY CONTROLLER
    Posted Apr 30, 2013 11:08 AM
    Those this happens with certain devices ?
    You should probably consider upgrading to a newer 6.1.3.x code .
    But before you do make sure you read the release code.
  • 3.  RE: ARUBA 650 BRANCH OFFICE MOBILITY CONTROLLER
    Posted May 03, 2013 05:52 AM
    Many thanks for your reply.
    Could you direct me to a location where i can download the latest sw and any instructions on how to load it ?
    thanks in advance
  • 4.  RE: ARUBA 650 BRANCH OFFICE MOBILITY CONTROLLER
    Posted May 03, 2013 06:48 AM
    You can go here :
    Support.arubanetworks.com >download
  • 5.  RE: ARUBA 650 BRANCH OFFICE MOBILITY CONTROLLER
    Posted May 03, 2013 09:59 AM
    appologies for my ignorance.
    i have tried to find the software
    http://support.arubanetworks.com to no avail.
    im looking to upgrade my controller from 6.1.3.1 to a newer version, could you direct me to the link ?
    also do you know of a prefered FTP program i could use to load this ?
    thanks again
  • 6.  RE: ARUBA 650 BRANCH OFFICE MOBILITY CONTROLLER
    Posted May 03, 2013 10:02 AM
  • 7.  RE: ARUBA 650 BRANCH OFFICE MOBILITY CONTROLLER
    Posted May 03, 2013 10:13 AM
    no, will i have to set one up ?
    what about FTP program ?
    thanks
  • 8.  RE: ARUBA 650 BRANCH OFFICE MOBILITY CONTROLLER
    Posted May 03, 2013 10:19 AM
    In order for you to have access to those files (Download TAP to appear) you need to create an account , not sure if FTP is supported.
  • 9.  RE: ARUBA 650 BRANCH OFFICE MOBILITY CONTROLLER
    Posted May 03, 2013 10:44 AM
    thanks for that i have had to register and it takes up to 3-5 days !!!
    looking for sw above 6.1.3.1 for my aruba 650 controller with install instructions, could you help while my registration takes place ?
    thank you
  • 10.  RE: ARUBA 650 BRANCH OFFICE MOBILITY CONTROLLER
    Posted May 03, 2013 10:49 AM
    You should probably should open a TAC case and ask them what's version OS they recommend for your setup .
    Make sure you read the release notes .
    You should probably wait until you have access so you can get the installiation instructions based on the AOS version you will install.
  • 11.  RE: ARUBA 650 BRANCH OFFICE MOBILITY CONTROLLER
    Posted May 03, 2013 10:52 AM
    ok will do, just wanted to play with the controller over weekend.
    thank you for quick replies.
  • 12.  RE: ARUBA 650 BRANCH OFFICE MOBILITY CONTROLLER
    Posted May 08, 2013 08:14 AM
    I now have the new software 6.1.3.6 these files are zipped.
    i have followed the best practices for the upgraded but a little stuck on the FTP/TFTP transfering of the configuration and installation of the software.
    i have backed up the config on th controller and it tells me that the config has been saved locally.
    i have used a used on free TFTP peice of software to receive the files to back up but i get the error PUT Access denied.
    is there a prefered or recommended FTP software anyone could recommend and a dummy crib sheet to help my on this software upgarde path.
    thanks in advance
  • 13.  RE: ARUBA 650 BRANCH OFFICE MOBILITY CONTROLLER
    Posted May 08, 2013 08:37 AM
    Can you please share the commands you are using to transfer the files over like the config and AOS ?
    It shouldn't matter what tftp software you are using but I use tftpd32 , it works pretty good.
  • 14.  RE: ARUBA 650 BRANCH OFFICE MOBILITY CONTROLLER
    Posted May 08, 2013 10:13 AM
    The TFTP program automatically listens on ports see attachment.
    As it was being blocked and i could not receive anything i did a factory reset from the WEBUI .
    Now i cant talk via the console port or the WEBUI - not sure of the default IP address.
    Things are going from bad to worse.
    Im at the stage where i will pay someone who can help me with this  (remotely via the web).
  • 15.  RE: ARUBA 650 BRANCH OFFICE MOBILITY CONTROLLER
    Posted May 08, 2013 10:28 AM
    OK i have found out the issue with TFTP software it was only set to Read only.
    I still cant talk to the controller via WEBUI or the console port
    helllppppppppppppp
  • 16.  RE: ARUBA 650 BRANCH OFFICE MOBILITY CONTROLLER
    Posted May 08, 2013 10:36 AM
    Open TAC case and Aruba support should be able to assist you.
  • 17.  RE: ARUBA 650 BRANCH OFFICE MOBILITY CONTROLLER
    Posted May 08, 2013 08:22 AM
    thanks in advance
