About licenses and testing between testing controllers
  • 1.  About licenses and testing between testing controllers
    Posted Jun 04, 2012 04:18 PM
    Is it available to use a license from a controller 3600 to test a lab environment and import the license to the same model controller in lab?
    Current OS: version 3.4.0.7
    Controllers: Production 3600 / Testing: 3600
    License file already exported to a tftp
    #3600
  • 2.  RE: About licenses and testing between testing controllers
    Posted Jun 04, 2012 04:23 PM
    Licenses should only be transferred due to RMA'd hardware AFAIK.
  • 3.  RE: About licenses and testing between testing controllers
    Posted Jun 04, 2012 04:48 PM
    Im able to import the licenses, but when I reboot the controller the licenses are not there, is this the reasson that I cant see the licenses after rebooting? That needs to be resent by aruba support ? I dont understadn the process.
    thank you.
  • 4.  RE: About licenses and testing between testing controllers
    Posted Jun 04, 2012 04:51 PM
    Licenses are tied to the serial number of the controller.  If you export them, you can only re-import them into the same controller.
    If the hardware dies, you can transfer the licenses to your replacement hardware.
  • 5.  RE: About licenses and testing between testing controllers
    Posted Jun 04, 2012 04:59 PM
    Ok , understood. So for this I will need to ask for demo licenses right? Are those licenses can be automatic downloaded or generated in the support page?
    Thank you
  • 6.  RE: About licenses and testing between testing controllers
    Posted Jun 04, 2012 05:11 PM
    TAC or your local account team should be able to get you eval/demo licenses.
