Airwave RAPIDS on a Public WiFi
Hi
Should I turn off RAPIDS notifications on AIRWAVE if I am deploying Public WIFI in an outdoor enviroment?
There will be lots of other Access points but due to this being a public deployment. We will have no control over these devices and they may be in the same are but they will not be on the LAN infrstructure.
Scott
Re: Airwave RAPIDS on a Public WiFi
You could possibly setup a rule that detects an SSID with a similar name being discovered and use wildcards to cover a few different variations.
If you are managing the switches in Airwave then you could also add a rule that if it is detected both on wired and wireless to trigger a classification.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACMP
[If you found my post helpful, please give kudos!]
That's totally up to you. You can modify the tirggers and RAPIDS rules to better match the environment, or disable if you want.
Jerrod Howard
