Android Xperia slow roaming
  • 1.  Android Xperia slow roaming
    Posted Dec 08, 2016 04:57 AM
    I'm experiencing a strange issue with some Xperia X with Android 6.0.1
    I founded that this phone are not able to roams correctly. Actually the phone wait for the very low signal before roams to another AP and we've got disconnection...
    We tested with one Nexus and Iphone which the both works like a charms...
    i've check this document :
    : https://community.arubanetworks.com/t5/Controller-Based-WLANs/How-to-improve-client-handover-and-roaming-between-AP-s/ta-p/180542
    all are activated excep the handoff assist which cause bad experience...
    Anyone experiencing this issue ? or how i can improve this behaviour ?
    Many thanks in advance.
    Michael
  • 2.  RE: Android Xperia slow roaming
    Posted Dec 08, 2016 10:12 AM
    Install "Aruba Utilities" from the google play store and see the signal strength of all the APs in that area when you connect to that SSID.
  • 3.  RE: Android Xperia slow roaming
    Posted Dec 08, 2016 10:24 AM
    Many thanks for your answer.
    Do you have any tips and tricks on this app ? or something that i need to take care when i'll analyze the wifi connection over this app ?
  • 4.  RE: Android Xperia slow roaming
    Posted Dec 08, 2016 11:03 AM
    The APP tells you the signal strength of neighboring APs from the Xperia perspective.  Click on "Not Filtering SSIDs" to only show the APs on your client's SSID.
