Ap105 not pingable in 6.1.2.5
  • 1.  Ap105 not pingable in 6.1.2.5
    Posted Jan 12, 2012 03:18 AM
    I guess this is a simple question but i cannot seem to find out why I cannot ping the AP105 from the normal lan.
    Is there a setting in the ARUBA that blocks icmp to the 105 AP's?
    Or is this a normal behaviour in this release as i can ping it from other reslease versions?
    ThnX ALL,
    Marcel
  • 2.  RE: Ap105 not pingable in 6.1.2.5
    Posted Jan 12, 2012 05:46 AM
    Can you ping it from the controller?
  • 3.  RE: Ap105 not pingable in 6.1.2.5
    Posted Jan 12, 2012 05:53 AM
    Yes i can ping it from there.
  • 4.  RE: Ap105 not pingable in 6.1.2.5
    Posted Jan 12, 2012 05:57 AM
    What is the default gateway on the AP's LAN and what is the default gateway on the regular LAN?
    Can you ping anything else on the LAN that the AP is on?
  • 5.  RE: Ap105 not pingable in 6.1.2.5
    Posted Jan 12, 2012 08:12 AM
    I am running 6.1.2.5 on a M3 and all ap105's are pingable. both from controller and network.
  • 6.  RE: Ap105 not pingable in 6.1.2.5
    Posted Jan 12, 2012 10:49 AM
    Thnx all,
    Let me do some investigation first on the lan first.
    Maybe it still may be a routing issue.
